Posts: 79 Likes: 6
Posts: 79 Likes: 6 |
Picked up a 235 to replace my 216 in my 50 chevy. The "56 engine has the number "037I532F56Z" The 4th character is not a 1, it is clearly an I. I can not decipher it, Could someone help? this is the number stamped right behind the distributor. Thanks in advance... Jeff
F = Flint 56 = year Z=passenger car with standard transmission.
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
I could be wrong, but I believe Chevrolet used the I stamp in place of the 1 stamp at that point in time. So when you see the I in a string of numbers, it usually should be read as a 1.
Ole S Olson
Posts: 79 Likes: 6
That will explain a bunch. Thanks guys
