Hello Paul-
I am not familiar with Clausen All-u-need, so I can't give a recommendation. I agree that an acid etch primer is a very smart way to go, but I'm not sure about using one that claims to be high build because you might be eliminating a very important step... sealing . In the PPG system, that I have used with great results, they recommend first an acid etch primer, sealed by an epoxy primer, and then followed by the sandable primer, if necessary. I would think that if you accidentally sanded through the "All-u-need", you would be in a bare metal situation again, leaving the integrity of your paint job in doubt.
I know this doesn't address your question directly, but I didn't want you to think we were ignoring you! :)
Speedline
