#46736 01/09/03 03:32 AM
I have been working on re-finishing the fenders/running boards my 28 coach.I know that gloss black lacquer paint should be used,but i am having difficulties purchasing '' any '' autotmotive lacquer paint in my area. :( Has anyone used any other type of paint other than lacquer on the 4-banger chev's? and how bad of point deductions would occur if lacquer is not used? I am aware that there are some vintage suppliers out there,but the cost is high !! :confused:
isn't 28 great
#46737 01/09/03 03:56 PM
The fenders, splash aprons and running boards were not originally painted with lacquer paint. They were dipped in an enamel type paint. Any single stage paint system will work. I recommend either catalysed enamel or polyurethane. All major automotive paint companies have both. Either is tougher than the original and a bit more shiney to a lot more shiney for the urethanes.
#46738 01/10/03 12:16 PM
Like Chip said use a good brand acrylic enamel with hardner ,I like Dupont Centari , let it set for a few daye until it is cured ,then water sand with 900 grit wet or dry and compound with a buffer and it will be very hard to tell from lacquer. It will look like new factory fenders.
auto
woody
#46739 01/10/03 01:27 PM
Like WOODY said, I used Dupont Centari Gloss Black and the shine, duarability and looks is beautiful. In my opinion, And others who have used Dupont Centari, You can not go wrong. :) :) chevy chevy chevy :) :)
