I'm installing the Fuel Tank cover (rear cross member cover ?). If reading the parts book correctly, it calls for a shim. Anyone have any idea what size and where it goes? Also says bolt (no size shown) and a 3/8 Shakeproof Lockwasher. Do the bolts go in before the body sits on the cover? Any help is appreciated.
BUMP
Hello nhinchas,
I sent you a PM
Thanks for your help , will proceed as you suggested. Thanks again
