Posts: 87 |
I have a 1950 Styleline Deluxe. The wire to the heater motor has come off. The wiring diagram in the Shop Manual does not show heater wiring---at least I don't see it. Where does the wire from the heater motor attach under the dash? Because it is not connected, is that why I keep blowing the 15 amp fuse on the instrument panel junction box? Everything works except the instrument dash lights. Thanks
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
The motor wire connects to the heater switch. The heater is an accessory and was dealer installed so the instructions will not be in the service manual but rather the accessory installation manual.
Posts: 87 |
Thanks. I got it working.
Posts: 87 |
As a followup---do you know where I can go to find the installation/schematic for my heater which is a Harrison Model HD-05-50? Thanks
The heater is an accessory so the diagram will be in the accessory installation catalog.
Posts: 87 |
