well FINALY got a break in the weather to get the engine back in the car !!
it snowed Friday night and Saturday morning, but was a grass snow, all the roads and driveways were just wet. about an inch of snow on the lawn and rooftops. so Saturday afternoon prepped the car and engine to go back in. my garage is NOT deep enough to load it in the garage, so have to roll the car out of the garage back to the cowl, then roll engine in front and drop it in.
engine connected to load leveler on engine lift
front of car prepped for entry
Test photo. I tried posting a photo and no go so I think we have a system problem as previously I had no problems posting a photo. I have posted the results in the Comments/Suggestions forum .
Took some time and made sure everything was lined up, then secured the driveline to the frame, as well as the u-joint housing to the transmission. also bolted up the brake cross shafts to the transmission as well.
figured get this in, then i can finish the line from the fuel tank to the pump. this way there is nothing in the way. i marked off where the starter sits so that i can go around it.
Engine is looking good, and project well documented as always, I really enjoy your detailed pictures.
Thank you, i take a lot of pictures for my own reference and glad to share them with others to help them
Originally Posted by Morten
Is the gray paint from Filling Station, and is the color we see in the last 2 pictures, close to what you see in person?
Yes that is the Gray from The Filling Station, and the color in the pictures is pretty close to what i see, they were taken in doors under fluorescent light
Installed the passenger side splash pan last night. always a fun task getting it in there just right and all the holes lined up. figured get that in before anything else so that i have more room to work around to get it situated  Â
Drivers side will go in later, doing one side at a timeÂ
next up was the starter, get it in, lined up and then power from the battery and then the wire to the dash pretty simple install, the Rubber boot was added after several discussions and an incident where the electrolock cable brushed by the starter post and threw sparks everywhere !! this isolated and protects the starter post which is positive (Direct to the Battery) from the electrolock (which is ground)
used my compression gauge to ensure i had cylinder 1 at Top Dead Center (TDC) this way i can set in the distributor and ensure it is on 1. used my tool and lined up the oil pump so that the distributor can seat fully. dropped in the thrust washer, and after a little tinkering and adjusting it dropped right in. installed the spark cable bracket to the block, put in the distributor adjustment screw for the spark cable, this limits the range/motion of the distributor when using the spark cable.
adjusted and set the point gap to .018", should be rough timed for now
secured the distributor in placeÂ
next up i put the spark cable in place and made sure it worked and moved freely, also put in a few drops of oil in the line to keep it freely moving.
now hte electrolock, luckily i have a colored cheat sheet that have been using, and done this a few times, so was not that difficult. always double check the order and that everything is in its place, especially the isolators for the points/contact. then secure it in place.
dropped in a new rotor button and distributor cap.
