I installed the board style LEDs in my "36 Chevy truck, then my '35 Chevy Standard coupe. I used the board style units from The Filling Station. The results are excellent but if you want a tidy and undetectable installation, it takes some some time and trouble.
The original truck lamps have screw terminals on the back side for eyelet connections on the harness. I had a supply of damaged and incomplete buckets so I rebuilt them to look correct on the outside with connections for the LED wires on the inside. It made for a very nice looking final product, but I had many hours of development and reconstruction in them. This is the fun part of our hobby for me. I am not complaining. The lamps I used would have required just as much, or more, work to return them to their original function.
The car lamps of the period had pigtails with twist lock connections. I salvaged connections from some old harness parts and the install went well.
The big problem with these conversion kits is that the method of retaining the board inside the lamp bucket is dodgy, at best. They are expensive but the results are very satisfying and make for a MUCH safer driving experience.
More recently, I bought LED headlamp bulbs from a Model A supply house. I got them for my truck, but decided to put them in the car instead. They are quite an improvement. The Filling Station is now offering an LED bulb which promises to be even better that the ones I used. I am planning to get a pair of them for my truck and if they pan out, I will replace the ones in my car with another pair. I have a Model T project in the future, for my Grand Daughter. The LEDs from the '35 coupe will end up in the T.
Another great feature, of the LED headlamp bulbs, is that they draw such a small amount of current that my dash lights are noticeably brighter.
