#465496 01/13/22 08:54 PM
m006840 Offline OP
I might be getting senile however previously when I went to the chat site my log in status was visible-there was a log in or log out button. It has disappeared and right now if I want to log out I need to use the drop down box next to my user name. Just curious if that is an update and if there are other modifications being worked on.
m006840 #465497 01/13/22 09:10 PM
My screen looks different too.
Jon T.
m006840 #465510 01/14/22 06:01 AM
In the members only section Peter Gariepy posted that there would be some changes in the near future though I got the impression it was to be a bit later than now.
m006840 #465518 01/14/22 08:47 AM
Hopefully the ability to change the page appearance will return soon. I'm not a fan of the UBB default skin but that's the only option I see at this time.
m006840 #465577 01/15/22 02:49 AM
I understand part of the changes will be a newer version of UBB.
Some of us will remember the problems Bill Barker had with an upgrade or server change a few years ago.
m006840 #465585 01/15/22 09:38 AM
The direct link to information about the 60th Anniversary Meet is gone. Where can I go to keep up with this important event without having to download the G & D every time?
m006840 #465604 01/15/22 04:15 PM
So now, the entire look is smaller. Guess what, most of the people who visit this site are just a little over 30 years old. You are making it harder to enjoy this web site.
m006840 #465605 01/15/22 04:26 PM
The forum styles can be changed via one time at the footer.
Or permanent by visiting your preferences in the drop down menu under your name in the top right when you click on it.
For now there are only 3 but I will be adding a few more.
But Peter will need to approve them for use.
As far as smaller it may be due to being mobile friendly now but I need to talk to Peter about making this full screen on a desktop first.
That may help
Currently it is set to fill 90% of the screen.
There is no such thing as stupid questions.
Just stupid answers.
m006840 #465608 01/15/22 05:04 PM
VCCA Member Services
Yes, you now must log out using the dropdown.
VCCA Member Services Manager
http://vcca.org
memberservices@vcca.org
708-455-8222
Tiny #465609 01/15/22 05:04 PM
Working on the template now. :)
http://vcca.org
708-455-8222
Hawkeye #465610 01/15/22 05:08 PM
It's back. Top right corner.
http://vcca.org
708-455-8222
Hawkeye #465611 01/15/22 05:09 PM
Actually the template has not changed. Font sizes are the same.
Regardless, I'm planning on changing the template completely in the coming days. Stay tuned.
http://vcca.org
708-455-8222
m006840 #465619 01/15/22 05:48 PM
Too bad the changes are for the worse nou
The font size definitely does not look the same on my screen.
And I have to enlarge now to read it comfortably.
Never had to do that before.
Staying tuned for the changes in the coming days! :-)
Ole S Olson
Stovblt #465626 01/15/22 07:35 PM
m006840 Offline OP
I also had the small size . Not sure why as previously my screen was set for 110 % zoom. After the changes when I checked it was 100% so I am guessing I previously changed it and with the updates lost that setting. I just went in to my " Application Menu' and reset it for 110 % and all is fine.
m006840 #465628 01/15/22 07:56 PM
I'll fix the font size as soon as we get the template issues resolved. Soon.
Thanks for your patience.
http://vcca.org
708-455-8222
Chev Nut #465629 01/15/22 07:57 PM
Anything in particular you find worse?
http://vcca.org
708-455-8222
m006840 #465641 01/16/22 03:29 AM
What happened to the moderators forum? Went to read it tonight and it has vaporized.
m006840 #465659 01/16/22 01:32 PM
Tonyw.
Updating permissions for all moderators. you'll have access again shortly.
Thanks for your patience while we dial in the update.
http://vcca.org
708-455-8222
m006840 #465668 01/16/22 02:29 PM
Hi Peter
I have a question/suggestion.
I've never been able to attach pictures to private messages.
When I click on "use full editor" for a private message, the attachment manager doesn't come up.
Is this normal? Or am I just not seeing something I should?
Being able to attach pictures or drawings would really be useful when trying to help someone who has PM'ed me a question.
Can this be done?
Thanks!
Ole S Olson
Stovblt #465699 01/17/22 11:46 AM
Can this be done?
Unfortunately no, its not a feature of the software that I can see.
http://vcca.org
708-455-8222
Can this be done?
Thanks for looking into it.
It is unfortunate.
Ole S Olson
m006840 #465783 01/18/22 09:12 PM
Stovblt, I'm wondering the same thing. Just tried to PM a member some pictures and no-go.
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
m006840 #465797 01/19/22 11:01 AM
Well you can insert a image in a private message you just can't download a image to use like the attachment manager.
The image first needs to be somewhere on the internet.
Then copy the URL and using the insert image link enter the url.
That tool is a image such as [Linked Image from ubbcentral.com] in the tool bar
Try this for a example in a private message
In the insert image add
Code
https://cdn.ymaws.com/vcca.site-ym.com/resource/resmgr/vccachatter_forums_logo.png
Which is the vcca logo at the header of this forum.
m006840 #465801 01/19/22 01:15 PM
I just noticed the history on the 29-32 section only goes back 11 pages. Did I miss something on that change, is it temporary , or on my end?
