Hello Steve Smith,
I do not know what year Chevy car or truck that you are working on. If you include the year and model, that would be great. The Filling Station has Tech Articles. In the alphabetical list under Mechanical is, Tie rod & drag link end repair 1927-1959. It is worth reading, but it does refer you to the shop manual for your specific vehicle and for the specific order of parts installation. However, I will repost a post that I made concerning the 1931 Chevy car repair manuals order of tie rod end components. Disregard if not applicable to your vehicle:
My Chevy repair manual for the 1931 concerning the "steering connecting rod" (the rod from gearbox ball to the forward left front spindle arm ball), : Gearbox end- From alemite grease fitting outward- Cup, ball, cup, spring seat, spring, threaded plug, cotter pin. Axle or spindle arm end: From alemite grease fitting outward- Spring seat, spring, cup, ball, cup, threaded plug, cotter pin. Adjustment: Screw plugs in tight and back off to first cotter pin hole. Now, if you are interested in the "axle tie rod" (the rod from the rear ball of the left axle/spindle to the rear ball of the right axle/spindle: Both ends are the same- from inward to outward- Spring seat, spring, ball seat/cup, ball, ball seat/cup, threaded plug, cotter pin. Adjustment: Screw plugs in tight until springs are compressed solid and back off to first cotter pin hole. Align the notches of the ball seat/cups to line up with the ball neck. Chevrolet Repair Manual- Independence Model-Series AE-LT- March 1st 1931. Manuals are a good thing to have.
