The BFG tires that came on the 41 Kingston Grey Cabriolet I bought a few years ago are well out of balance. More weights on them than a fisherman would use in a lifetime. In spite of all the weights it is still not smooth and I was advised by the tire shop to run the worst two on the back.
This past Hershey I bought five new Firestones for it. They didn't have any inner tubes but when I visited their place at the Moulire GA swap meet they had some. I was told that they had the ones with fat valve stems. So I got a set of them. Still haven't had the tires and tubes mounted. I'll let you know how they work out when I do.
The 41 Coupe has a set of Bedfords on it and they still look good but they don't have much tread left on them. Those were good tires and balanced out real well.
I'm thinking of buying a set of Diamond Backs (DB) for it.
Question: What size DB radial is the closest match to the size of the 600x16s and what would be the size next up If I decided to go to a bit oversize or is that practical?
Thanks,
Charlie
