The regulator is attached to the header board from the back side thus it needs to be removed as a unit. You can then lubricate, clean and repair if necessary. While it is removed check to be sure the windshield does not bind in the side tracks. I believe the control handle is held to the shaft with a clip same as the door regulator handles but not entirely sure as my car is a 32. I do have a handle for a 31 and will check if I can find it. Be careful removing the handle as it's pot metal and is easy to break. Learned that the hard way. The regulator board has two screws on each end that hold it in place. Not sure but I believe the upholstery is attached to the board and also the wiper motor is attached. Hopefully someone with a 31 can verify that the above is correct for the 31 . The service manual I have shows how to lubricate the mechanism when removed but not how to remove it.
