Posts: 80 |
The left tie rod on a 1953 car threads are a little messed up. Would like to chase them with a die but need to know what size threads and number of threads , thanks
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
You might need a left handed die depending upon which end of the tie rod is damaged.
I suggest a thread file to clean up the threads on the rod. The files work well on external threads and generally have 8 different thread pitches (four on each end). The three files I have can be used on 24 different tpi (threads per inch) threads. Don't need to use them often but have been a GOD send more than once.
I like Chipper’s suggestion. You do not have to worry about the thread direction with those files.
One other trick I use is to make a “thread chasing die” from a nut that fits the threads. I use a small triangular file to cut 3 or 4 tapered grooves through the threads in the nut. Thread it on the male thread with some cutting oil. Turn it about 1/2 turn on and then 1/4 turn back, then 1/2 turn forward and 1/4 turn back. Keep doing this until the grooves get full and the nut is hard to turn. Remove it and clean the grooves. Repeat as necessary.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
ChetC, According to The Chevy parts catalog, the size is 9/16 - 18. It also indicates that the left side would have LH threads. A new tie rod end is probably cheaper than a die. I have them with both LH and RH threads. Send me a PM or give me a call, if you want. You can find them on eBay or from many of the vendors, as well.
Mike 573 864 6539
Posts: 80 |
All good suggestions, thanks
