#461144 08/28/21 02:12 PM
I have a small block V-8 with a casting number of 3932388 and a code of HV on the stamp pad on the front of the block. When I look up the casting number it states it is a 350. However, the HV code indicates a 327, which would be correct? it does have a 327 intake on it, rams horn exhaust and the alternator correct bracket for a 327. Bit confused by the casting number. Any ideas?
Wilwood Engineering1955-1957
1968 to 1979 350. With 4 bolt mains ,
http://outintheshop.com/faq/casting/castings2.html
JACK
Thanks for the input
http://www.chevy-camaro.com/chevy-camaro-chevy-engine-suffix-codes.php?group=4
1969. Turbo hydromatic with 255 Hp. HV. Suffix,
There should be some block casting dates on the block and the heads under the rocker covers,
JACK
i need to look at the heads. when i decoded the intake, water pump and distributor they all came back as from a327
Take a look here,,,might be helpful.
http://chevellestuff.net/home.html
Support The VCCA!
Member Photos
1918 D5 V8 pictures
1918 D5 V8 pictures
by Mel1940, November 18
Progression on the 64 Impala SS 409
by DreamChevy, October 21
1964 Chevrolet Impala SS 409/425
by DreamChevy, October 10
4th Annual Gulf Coast Region car show
Who's Online Now
1 members (Mike Deeter), 22 guests, and 13 robots.
Key: Admin, Global Mod, Mod
Newest Members
Budinski, timmy25252, Warburton, joshuagiddy, Roy1956
17,703 Registered Users
Today's Birthdays
30ChevyOkla, dandyd, Rustoholic
Forum Statistics
Forums67
Topics57,293
Posts418,525
Members17,703
Most Online1,133
Jan 22nd, 2020
