Posts: 168 |
I have a small block V-8 with a casting number of 3932388 and a code of HV on the stamp pad on the front of the block. When I look up the casting number it states it is a 350. However, the HV code indicates a 327, which would be correct? it does have a 327 intake on it, rams horn exhaust and the alternator correct bracket for a 327. Bit confused by the casting number. Any ideas?
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
JACK
Posts: 168 |
Posts: 168 |
i need to look at the heads. when i decoded the intake, water pump and distributor they all came back as from a327
Topics59,071
Posts429,077
Members18,308
