#463295 11/03/21 07:35 PM
What is this threaded shaft with nut at the base of the distributor?
Is there any trick to removing the distributor?
That threaded shaft holds the oil pump in the block. To remove distributor remove the screw with the spring on it. Distributor will lift straight out.
Thyanks Tim!
