I have been messing around with a pretty fair 1929 2Dr. It has a straight six. 6VDC system. It won't start. I pulled #1 plug and saw a spark, albeit a weak spark but a spark non the less. I removed all of the plugs gave them a quick blast checked the gap .040. New distributor cap, contact breakers and a new battery. I drained the fuel tank and all associated fuel lines. I sprayed fuel directly into the intake and cranked away. Nuthin. Zero, nada, not even a pop. I pulled all of the plugs again and checked compression, all six were between 80-85psi. So the way I see it, I have compression and I have fuel it has to be this 6VDC ignition system... I hear tell 18* BTDC, but I really don't know. I don't even know if there is a way to hook up a timing light. Is there a calibration mark on the crank? Is 18* correct? This updraft carb I pulled off is a pretty neat carb. I have not a clue if it works well or not. It is a single bbl updraft with a big brass float bowl and a very cool brass float and a great big long external accelerator pump. Lot of whatever was in there I cleaned it all out .. This thing should run. It is a nice looking vehicle probably in better than fair to good condition....What am I missing?
