#463007 10/26/21 05:53 PM
Davem68 Offline OP
Hello
Does anyone know when I can purchase/rent/ borrow the gage needed to set the center section for my 28 coupe?
Davem68 #463025 10/27/21 11:24 AM
I bought mine from the Filling Station. Here is the page from their online catalog: 1928 Chevy Brake Linkage tool
Davem68 #463037 10/27/21 01:26 PM
As some of these old cars wore out parts were robbed off of other rigs. First make sure you have the '28 brake cross shafts. For '28 the brake cross shaft ends point down, and in '29 they point up. Through experimentation they figured out there was more force that could be exerted against the brakes with the shaft ends pointing up. This was the last improvement they did to the 28/29 front configuration. The 29 rear brakes were different, and in '30 everything on the cars was new, bigger, and better. The 28, and 29 brake gauges are different. Not by much, but some.
The other thing you should do in my opinion is step up and buy a set of the trunions for the front pivot. The original white metal is extremely brittle and you do not want that failing when you might need it most. The 28/29 brakes are functional but small, and marginal as to their effectiveness. All linkages and pivot points should be annually oiled, and if that is done will last almost indefinitely.
Art
beachbum #463048 10/27/21 04:52 PM
Davem68 Offline OP
Rustoholic- Thanks for the info!!
beachbum-Thanks, the ends are pointing down, and ill look into the front pivot when i make it up front! Thanks for the info
