#462803 10/20/21 12:07 PM
DMelton Offline OP
Do these come off relatively easy, or does all the front sheet metal have to come off also?
I saw that the Chev engineering bulletin states the radiator support, fenders, etc are tied in together at the front cross member.
Thanks,
Doug
When I took my 35 standard apart the fenders are bolted to the grill shroud. It can be done without taking the radiator shroud off. the frame/ cross member.
CarDC
CarDC
VCCA# 52964
35 Chevy standard 3 window coupe
