#462576 10/11/21 02:26 PM
Nazario Offline OP
Hello, I got a friend that has a 1937 Pontiac with a flat head 6. He would like to convert it over to a 12 volt alternator. Does anyone know if they make a bracket to mount the alternator on the engine? or where I can buy one? Any help would be appreciated
Thank you for your time
I suggest you should check with a classic Pontiac forum. There are probably supply houses that specialize in older Pontiac’s.
Nazario Offline OP
I found a bracket
