Posts: 15 |
”˜48 Fleetline with a ”˜52 235 rebuilt 2000 miles ago. Starts great when cold, I have an electric primer pump, but after she’s up to operating temp it just won’t fire. Seems to turn over a bit slower? Valves are right, just installed a new vacuum advance and set the timing with a light. Car runs fantastic just won’t start after it’s warmed up? Any ideas, I don’t know what else to do?
'48 Fleetline Sportmaster
Three ignition components and battery cable ends are likely suspects.
As temperatures rise so does resistance in electrical connections. Make sure that all connections are clean and tight. A little dielectric grease may not hurt.
Wires inside coil lengthen, internal shorting is possible. Cool by pouring water on coil to see if that helps.
Corrosion on points can dramatically increase resistance when heated. Clean points and maybe reset.
Shorting in condenser more likely when hot. Replace if questionable.
If the restart problem occurs after 5-30 minutes after being shut off, it may be gas percolating into the intake manifold from carburetor. Fully open throttle plate while cranking to clear too rich mixture.
There are a few other possibilities but the above are by far the most likely.
Posts: 327 Likes: 1
Posts: 327 Likes: 1 |
A hot motor will have more compression and puts more demand on Battery..... So when its hard starting, and turning slower i suspect battery first, or battery. Lets us know what you find. .
1937 Chevy 1/2 ton Pickup 1950 Chevy Styleline Deluxe Coupe 1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
Posts: 15 |
I went back and checked all connections, checked resistance on several wires to and from the coil, both cold and hot and found nothing out of ordinary. I think maybe the starter is a bit weak? I retarded the timing a few degrees and that seemed to help, seemed like the motor spun over faster. Is it time to have the starter looked at?
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
Dan, If the car is still 6 volt, check that the battery cables the proper gauge. Even with good connections, smaller gauge replacement cables may be the cause. Mike
Posts: 327 Likes: 1
Spark is the first thing to check. Pull the wire from the coil to the center of the distributor cap and arc it to ground while cranking. I don't have an idea of the minimum acceptable jump distance, but I'd sure be looking for more than 1/8". Both coils and condensers can get worse when heated. I once ran a '53 Chevy in very cold weather. I had a 6V motorcycle battery in the front seat and could switch the ignition system to it for cranking. It would start with amazingly slow cranking, maybe 60 RPM. Be sure your accelerator pump is working, but don't overuse. With practice, you can sometimes get a start by releasing the starter button just before a spark fires. The rise in battery voltage when you remove the starter load can give you a nice spark on the next point opening. Triple check point spacing Wilson
Wilson
Posts: 15 |
Thanks for the tips Guys. Battery cables are big and new, I forget gauge, accelerator pump is working, points are right at .018 and clean. Wilson, you mention fire as soon as you let off starter, I remember this happening several times so that makes sense that part of the problem is a weak spark when cranking. Just replaced the condenser, I have another coil I may swap out when the motor is hot. Thanks again for the help, I really need to get this sorted, last weekend I carried a bride and her father to her wedding, well when we got the signal to go I had to get the dad to help push off the car to get her started!
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
I had a somewhat similar trouble until I stoped trying to burn ethanol fuel. A case of vapor lock.
J Franklin
Posts: 234 Likes: 5
Posts: 234 Likes: 5 |
My forty was almost impossible to start hot. Changed to non-ethanol gasoline. Problem solved.
