Since my Restoration is coming to an end, I have to go to a workshop soon to install the rear window.Before I wanted to check the camber of the front axle provisionally with a spirit level. Since the axle was overhauled with new King Pin Set and remastered ing shocks, the wheels were a little out of alignment after reassembling I put the car on jacks - under the lower spring seat - and took the wheels off. On the left side I get the wheel well adjusted, but on the right it does not go better than seen in the picture. How can this be, or do I have a thinking error? It is really only meant to be a rough adjustment so that the car runs straight out.
