I will email you pages 26-27 scanned from ”Combined Parts List Four-Ninety and Superior models … Effective on and after February 1st, 1924”, Below I call it ”List 1924”.
In the following text i will refer to the part numbers used on these pages in ”List 1924”.
If I have found a similar part in the ”Master Parts Price List”, covering twelve models, including H, 490, Superior and earlier and younger models, ”effective February 1, 1928”, ”List 1928” I will also refer to the numbers in ”List 1928”, with some comment from the List.
I took a look at ”Genuine Chevrolet Parts for Four Cylinder Models, Effective July 1,1940”. I found some details fitting the 490 or Superior, but no propeller shafts or -housings. This list is available on
Old online Chevrolet manuals see
index page.
First to your first question.
The propeller shaft bearings for Four-Ninety, ”For Use with Straight Tooth Bevel Ring Gear models”, that is 1916-1921 models:
… One ”Propeller Shaft Roller Bearing (Hyatt)” , H 1174.
List 1924:? Not on pages 55-58.
… One (or two?) ”Propeller Shaft Ball Retainer with 18 Balls”, H 51.
List 1924: 330797, with comments (1916-18) and (18 Steel Balls).
… One ”Propeller Shaft Ball Retainer with 14 Steel Balls”, 41239.
List 1928: 334125.
The propeller shaft bearings for Four-Ninety and Superior, ”For Use with Spiral Tooth Bevel Ring Gear models” that is 1922-1924, are:
… One ”Propeller Shaft Bearing Rear N.D., No 1307, Single Row”, 40283.
… One ”Propeller Shaft Bearing Front N.D., No 305, Double Row”, 48571.
The propeller shafts that corresponds to these sets of bearings are:
1916-1921:”Propeller Shaft, with Collar, Lock Nut and Pinion Nut H 669, Taper 13/16” Long (?, cannot read the small numbers! According to my notes the length is approximately 25 mm), Length of Spline 3 13/16” (?, cannot read the small numbers)”, 41986.
List 1928: Nr 329535, 490 (1916-21). (6 Splines) (52 2/3” Long) (2 1/16” Threaded Section for Collar and Lock Nut).
1922-1924: ”Propeller Shaft with Lock nut and Pinion Nut”, 24040.
The tapered en part, for the pinion gear, is according to my notes 50,5 mm.
List 1928: 337709, 490 (1921-22) Superior B, F. (6 Splines) (52 23/32” ? Long) (1” Threaded section for Lock Nut).
The propeller shaft housings that corresponds to these propeller shaft assemblys are:
1916-1921: ”Propeller Shaft Housing, with base”, H 18.
List 1928: Nr 334237, 490 (1916-1921).
1922-1924: Propeller Shaft Housing, with Base”, 24050.
List 1928: Nr 342023, 490 (1921-22), Superior B, F. Same as ”Lou” mentions in his post to ”gregs 24” in his thread ”24 propeller shaft housing”.
Note that on 490 1921 model both types of propeller shafts seems to have been used.
Then to your second question.
As far as I can see from your pictures your propeller shaft is number 24040 (1922-1924), unless it is modified or special production. If it is 24040 your propeller shaft housing must be of number 24050, unless it is modified. So you can use 1922-1924 model of propeller shaft, number 24040. You cannot use propeller shaft number 41986.
Then there may be another crucial question: Does the propeller shaft housing 24050 fit if your 1916 has rear axle housing model for Superior 1924? In List 1924 the rear axle housing has number 341730. The rear axle housing for ”Four-Ninety and Superior 1923” has number 24078. Maybe they differ only on the brake parts, I don’t know.
