The front frame crossmember forward and aft edges are formed as an upturned channel approx. 1/4" deep x 1" wide. This channel was previously packed solid with hardened oil & road dirt, but now that it is cleaned out and painted it holds water. Has anyone else noticed this and did you drill a small weep hole to keep it drained ? Did Chevrolet division start putting weep holes in at some point ?
Kevin
I noticed it but never worried about it seldom drive in the rain
I drilled a weep hole in mine- front and aft
dick
