. Hi 37 Blue,
Thank you for the reply. I have looked all around the passenger door. Since Kettering usually put the ViN on the right side of GM vehicles, I concentrated on the right side for initial search. (Fisher, Martin-Parry, Flxible. Even my 37 Chevys with Proctor-Keefe, Crown and Superior bodies have it on the right. Holden has
them on the Left.) Here's a few photos of my search. .
. Pix #1 = Passenger door is located on Right side of Vehicle behind tire.
. Pix #2 = Looking back at courtesy light. .
. Pix #3 = Looking forward at door jam. Upholstery on door. .
. Pix #4 = I looked beside the second heater. (It has 3 heaters.) I haven't removed the heater to look behind it but most states require Vin to be visible. .
. Pix #5 = Factory photo of dog house. .
. Pix #6 = On the other side of the dog house, I looked all around the drivers compartment. (That's heater number one that doesn't work. The other 2 heaters do. The seat is a full 12" to the left of the Ross steering wheel [AKA: IH] causing me to hit the air over hydraulic brake pedal instead of gas, making double clutching Chevy 4 speed quite challenging.) .
. . I have a list of Who purchased each of the 164 Flx bodied Clippers that gives the model, ViN, and engine number. BUT the engine in it is a 1952 235 truck engine with no serial number. The correct replacement engine for heavy truck. When purchasing a "Crate" engine from the factory, someone was supposed to stamp the serial of the dead engine on the replacement. Obviously this didn't happened. I wish they would have waited two years and gotten a 1954 261 truck engine to haul this 9 ton Chevy around.
There's more Flxible info on my website at:
http://home.znet.com/x1937/Flx.htm>
. I appreciate your thoughts, . . Lou
