Posts: 521 |
I have many sheet metal parts, fenders, cab, doors, engines (207 rebuilt, '36 rebuilt, 216, 235), transmissions, wheels (1 1/2 ton and 1/2 ton), frames, steering columns, running boards, other misc parts. Located Ca. What do you need?
ron
ron
Posts: 136 |
CarDC VCCA# 52964 35 Chevy standard 3 window coupe
Posts: 42 |
Posts: 8 |
Hi, I am looking for a 1936 steering gear clamp for my 1/2 ton, a world famous steering gear restoration shop lost it along with a not so great overhaul. I have been told that 33-36 truck and master car interchange
Posts: 14 |
Hi, I am looking for a drive shaft of a 1934 Stanard 6 2 door sedan. 10 spline, following the repair manual it is a D type. I hope you can help. Regards
The 1933, 1934 and 1935 Standaed drive shafts are the same.
Posts: 521 |
Sorry, I don't have that part.
ron
Posts: 76 |
you have any parts for 35 master?
Posts: 521 |
Probably have grill, head/tail lights, engine, wheels and other misc small parts.
ron
Posts: 190 Likes: 2
Posts: 190 Likes: 2 |
Can you send me a couple pictures of the grill. 36 chevy coupe
1936 Chevy Coupe. All Original
Posts: 50 |
Do you have a driver's side tailight and mount for a 36 chevy? Thanks, Hendo
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
Do you need it for a Coupe or Sedan?
Jon T.
Posts: 50 |
Posts: 104 |
I need a rear right fender for a 1947-1953 1/2 ton Chevy truck
Posts: 402 |
Posts: 8 |
Hi I need speedo housing on back of transmission 590791 that fits a 1936 master or 1936 pickup
Posts: 521 |
Michael; did you get my message?
ron
ron
Posts: 467 Likes: 1
Posts: 467 Likes: 1 |
You have a good 32 transmission ?
1932 5 Window Confederate Coupe Best of Era 6 cylinder 2016 1968 Corvette Roadster 383 CI-425 HP 1938 Business Coupe "personalized"
Posts: 11 |
Looking for spar tire cover for 1935 and interior door locks
Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
Looking for a right side trunk hinge for 1936 sedan with trunk.
Posts: 3 |
do you have an operational temp gauge? I'd take it.
Posts: 521 |
ron
Posts: 521 |
Do you need the black face gauges or the yellow?
ron
ron
Posts: 190 Likes: 2
Greencorn,
Would you happen to have any 1936 chevy headlight bezels? And the ring right underneath that holds the light in? I believe it's the retainer ring, if that's correct. I only need one of each
Posts: 128 |
Howdy,
Would have a headlight bucket for a 1935 truck? The rustier that better. I would take the entire unit as well if needed.
