#460540 08/10/21 10:27 AM
MattD Offline OP
I’m looking for the washer that goes under the threaded cap the holds the gear shift in place, GM part # 4.029. For years I’ve had to periodically tighten the cap. A friend has an original Chev parts manual from the 30’s. I discovered there’s supposed to be a washer under the threaded cap to keep it from turning.
If anybody has one or knows a source, I would appreciate it. I couldn’t find one in the Filling Station’s catalog.
Matt
MattD #460619 08/11/21 09:47 PM
Youy see them at times on Epay.
J Franklin
MattD #461040 08/24/21 12:22 AM
Have you ever tried old car junk yards? There are some still around.
MattD #461483 09/06/21 07:12 PM
I don't know about a washer under the cap, but I have the collar that is under it. it takes the slop out of the shift rod for better shifting.
carson told you this!!
