Posts: 21 |
Hello Any one put electric fan in1928 chevy car or truck would like to know the Pros and Cons
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
What is making you think this is a solution? If the radiator or block are partially plugged this will only be a temporary fix.
Can you even find a 6 volt fan that fits?
Posts: 21 |
Hello Rusty37 Yes you can
Posts: 3,511 Likes: 48
Posts: 3,511 Likes: 48 |
Hi Rick, Are you having an overheating problem? Increasing the air going through the radiator might help, but it is not fixing the problem. Does your AB have the correct radiator shroud? If not, the fan blade on the engine will be very inefficient in pulling air through the radiator because it is so far from the back of the radiator. This shroud is a one year only thingee because the engine compartment was stretched in '28 by 4 inches to start getting ready for the inline 6 engine in '29. The shroud helps fill this extra space. Here is a photo of a '28 fan shroud: ![[Linked Image from i160.photobucket.com]](http://i160.photobucket.com/albums/t172/stovebltr/Stovebolters/Dean%20Rustoholic%20Meltz%20-%20toys%20and%20projects/temp-pics/1928_Engine_zpsykbk8tjg.jpg) Dean
Posts: 25 |
As an aside, what is the best coolant for these unpressurised systems?
Straight water, water-green antifreeze mix, something else?
Thanks.
Tim
Tim, here's a thread that eventually gets into a discussion about coolants on the second page. The first page is interesting too. ;-) Temperature discussion about '27 and '28 carsCheers, Dean
Posts: 25 |
Great read, thanks for the thread.
What beverages does Lurch and Justin prefer?
Tim
Both boys enjoy a 50/50 cocktail of antifreeze and water. Premixed by the gallon at the local car parts bar room.
;-) Dean
Posts: 656 Likes: 3
Posts: 656 Likes: 3 |
There are a whole bunch of different types of ethelyne glycol coolants now, not just "old green" and "the new stuff" anymore. Additionally the color does not mean anything. Colors were never standardized, but made more sense when there were only 2 or 3 types. Today, for any out of the ordinary use, you absolutely must read the datasheet.
Recently I had foaming problems leading to boil over with 2 different brands of traditional "green" pre-1995 style coolant. This was in a 36 Pontiac with an open system and a packing-type water pump. I then took a few different types of coolant, mixed 50-50 with distilled water, heated them to 200F, and beat the crap out of them with an egg beater. I intend to make a detailed post about this in the next few days at the AACA forums, and maybe here too if anyone is interested in hearing it.
The short answer is that Valvoline-Zerex G-05 looks like a good bet to minimize foaming in an open system. There are probably some other good ones. Nothing performed as bad as the recently bought "traditional" formulas that prompted me to test this.
Posts: 25 |
I would love to see your results. Please do post. T
