Need some help .. im trying to give my pops a hand with his 1936 standard. Keeps dying out when car is running a while and wont start untill it seems like the car cools down . Weve changed the points and condensor and coil. I checked while car was runing at the battery what the voltage reading was at it was 6 volts. Went to the generator and removed the wires that were conected to the metal tab on voltage regulator that said bat. The reading there was 23 volts . Is that normal or is voltage regulator bad ?
