Hello. I have a 1954 235 engine in my car and removed the valve cover and found what looks like grease on the inside of the top of the valve cover. Anyone know what it is or what is causing this. The motor was rebuilt 5 years ago and runs fine
The photo shows the grease is the same color as grease in a can or tube. I can't think how light brown grease can get there except by someone smearing it on the inside of the cover.
I agree with Chipper. That sure looks like a coating of grease was manually applied to the inside of the cover.
My next guess is that the engine has been run very little after that was done. I cannot see any indications of oil hitting the grease. I would expect that the hot oil splashing around in the valve cover would eventually “wash” the grease away.
I had a similar problem with my 54 235 solid lifter engine. The accumulation of grease or light brown slim was a result of a cracked cylinder head and it was boiling off antifreeze mixed with engine oil.
I initially took the head to an engine shop to have new valve guides installed thinking that was my problem, the shop found the crack in the head. Replaced the head and no more accumulation in the valve cover.
I hope your findings are different than mine were. Dave B
I am a retired CA (US CPA) living on Vancouver Island with my bride of 40 years, no dog no cat.
Like DWB_6 said, anti-freeze in the oil. I have run across this before and it was a bad head gasket. The anti-freeze mixes with the oil and you get a brownish slime. When I had the problem I just needed to replace head gaskets. Check it out before any real damage... Jeff
