50Grit Offline OP
I'm needing to identify engine model/displacement/year from casting numbers or other numbers on engine block, intake manifold, exhaust manifold, transmission.
There must be a chart somewhere. I haven't found it, yet.
I have what I believe is a '39 216 engine in a '35 Pick-up. I located what is reputedly to be a '35 engine to transplant back into the truck.
I'd like to id the transmission, also.
Other folks have been trying to get me to buy their parts/engines, but they have no good information as to model year/displacement.
Photo is supposedly the '35 Engine.
I have a copy of a great reference book:
Chevrolet
Casting - Forging - Stamping
Identification
Number Sequence Listing
Six Cylinder Models
1929-1942
Also Tons of info on google :)
this is a good resource as well:
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
http://outintheshop.com/faq/casting/castings2.html
looking at the casting number looks to be May 16, 1935
typical letter equal month, a=jan, b=feb
then day of month 16
then last digit of year 35
image is too small for me to see the casting block number
I've used the Stovebolt engine/casting number source before and it says a 1935 block should be an 837591.
It's hard to tell from the picture, but to my eye it looks like that's the number on your block.
Ole S Olson
50Grit Offline OP
The casting number in the photo is, in fact, 837591. My search efforts did not yield the info you guys shared. Thank You.
ok, in the casting book, i see 837591 for casting with 601423 part number in 0.033 group, BLOCK as description
looks to be 1935 207 CI straight 6
