So you full fielded it, and the voltage came up to something over 6.3, and you have verified the the regulator is grounded. Good. It should be pulling the cutout in. If it were me, I would carefully (with battery disconnected) drag some paper soaked in brake cleaner through each set of regulator points, carefully making the points drag the paper, but being careful not to bend anything.
Hook the battery back up, and if it doesn't start working, watch with the cover off and see if it is pulling the cutout in when the engine starts and revs up a little.
The cutout should definitely pull in at something below 6.3v at the generator, the manual might say what the actual cut-in figure is, but everything will be slightly off with the cover removed.
