Posts: 412 |
Front fender braces have a cast fitting where the two sections join. Any body know how these are installed?
1932 Chev 5 Window Coupe
Posts: 412 |
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
They are reinforcements that go inside the tubing to keep from crushing it when the through bolt is tightened.
Posts: 412 |
There are 2 bolt holes at that join. Do these go in the top hole? Is there a right or wrong side up? They appear to be tapered. Thanks.
