Thanks for the replies. Not being a genius, I think installed the Okie the wrong way. I had to get the u-joint housing off in order to install the conventional replacement bushing which has to be pinned. I had to partially slide back the transmission (on guide pins) to remove the housing. My housing was fairly banged up so I decided to replace it with a NOS one I found on ebay. All is well now. I guess you're never to old to learn.
Frank
1934 Master Sedan (almost finished)
1947 1/2 ton Thriftmaster (survivor, runs good)
1947 Aerosedan ( survivor, work in progress)
