I recently ask a question on my 1937 Chevy 2 door Sedan Master Deluxe headliner bows . So I have these metal bands inside the roof they are bolted to the body of the car . But I have to replace the headliner .So I have been told that the cloth headliner is held on by clips on the rail then wire across the roof. when the cloth is sew the wire runs threw the loop which holds the headliner up ???? if his is true were can you buy the wire and clips the hold the headliner up. Is this true ? if so who sells the clips and wire
