Was tired of fiddling with the carb and vacuum tank. I know that it will work great when in order but I just want to drive it and since the car have been so badly cobbled together I figured I would make it a little more comfortable for me. Flipped the intake and new carb for a 60s ford 6cyl.,electric fuel pump,real gas pedal and an ignition switch with starter solenoid. Next is cut off the brake pedal pad and turn it sideways because my super wide size 18 kinda does not fit between the brake and the shifter. Already heated and bent the shifter because my leg kept popping it out of first gear.
How's she run with the down draft configuration vs. original?
-Tyler
