Posts: 39 |
gas pedal stlff how to adjust 41 chevy truck
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I believe there is a bell crank on the block and you could lubricate it.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
Also inspect the bell crank and other pivot points for wear. It the bell crank is too loose on the pivot pin it will cause it to twist sideways and bind. Don't know if the throttle pedal is hinged at the floor but if so that will need cleaning/lubricating.
Posts: 217 Likes: 3
Posts: 217 Likes: 3 |
I had that exact situation on my 51. I lubricated the bell crank and problem solved. It probably needs to be done once a year after being stored all winter. Jeff
Posts: 39 |
I have replaced return spring and after four attempts have finally fixed problem.Runs like new.
