Hi Jim,
Part number 34100 is not in my four cylinder parts books, but the books do say that the correct flywheel has 110 teeth, so that's a clue.
As for the U|C mark, you can make your own. ;-)
When I was resurrecting my '28 Canopy Express, I found that the previous owner put the flywheel on incorrectly, so the U|C mark did NOT appear in the little window with the pointer (on the flywheel cover) when cylinder number 1 was at top dead center (TDC) at the end of the compression stroke. I did not want to pull the engine just to unbolt and re-bolt the flywheel on correctly, so I set cylinder number 1 at top dead center (TDC) at the end of the compression stroke (I had the oil pan off so I could see that the crank offset was pointing directly upward and I used a wood dowel through the spark plug hole to 'feel' that the piston reached it's top position) and then I painted a fluorescent pink line on the flywheel that lined up with the pointer in the window.
That was nine years ago and I still use the pink line to time the engine. Here's where I describe how I time and start my trucks:
Timing and starting a 1928 Chevy engineAfter you get the flywheel on with your timing line ;-), I do suggest that you mark that position of the flywheel with a couple of punch marks on the flywheel and the crank, and have the crankshaft balanced with the flywheel in that position.
