Yes, it is divided in to two compartments.
The trans fluid does not mix with the coolant. A thermostat in the trransmidssion allows the PG fluid to pass through the cooler when the fluid temperature exceeds 240 degrees. The fluid is heated up under conditins when the engines is pulling harder under speeds of 40 MPH.The1950-1954 Power Glides should never be run with the lever in the PARK POSITION FOR FOR MORE THAN A MINUTE OR TWO BECAUSE NO OILIS CIRCULATING IN THE TRANS,FOR LUBRICATION OF INTERNAL PARTS OR PASSING THROUGH THE COOLER IF (NECESSARY).'
PG fluid is checked with the engine idling and in neutral With cold flid it will be near the add mark and hot fluid expands the fluid so the it shorl be near the full maIt is acceptable to use LOw for starting off when is faster start is desired. You, can up-shift any where be tween 15 and 40 MPH.
