Posts: 14 |
Anyone suggest a type of springs and shocks I should buy that would give my Bel Air a smoother ride? Open to aftermarket and not sure if GM replacements would be worth it... for aftermarket might be better. Let me know!
Regards, Anthony
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I suggest that a low cost and simple first step is a set of good replacement shocks from maybe Monroe or Gabriel.
Most replacement so called performance springs are actually stiffer.
If you expect that car to ride like a 60’s Cadillac you might need to adjust your expectations.
If it has gas charged replacement shocks they are very stiff. The 1953-1954 had farly soft front ends and do not replace the springs IF they are originals.
Posts: 366 Likes: 1
Posts: 366 Likes: 1 |
New rubber bushings on the front sway bar will also help some.
Dean 50 - VCCA #44675
Posts: 14 |
My springs are original, shocks are a must and since I’m jumping under there I’m thinking about installing new bushings too. I just want the car to ride smooth and my hubcaps not to fall off when I hit a pothole.
Regards, Anthony
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
It will never be as smooth as a modern car but you shouldn't lose hubcaps.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
if hubcaps taking off, check that your rims have the four tits at 90 degree angles.they are designed to retain full size hubcaps. mike mccagh
