Posts: 373 Likes: 1
Posts: 373 Likes: 1 |
Will the exhaust manifold from a 1938 Chevy 216 fit on a 1951 Chevy truck 216?
VCCA Member 51121
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I think all the 216 manifolds were the same fitting to the head but may have a different exhaust pipe angle though that isnt hard to adjust with a pipe cutter and welder on the pipe. Tony
Posts: 1,139 Likes: 75
Posts: 1,139 Likes: 75 |
Does your truck still have splash/dust pans on each side between the engine and frame? If it does, and you want to keep them, you won't be able to use the earlier manifold due to the outlet angle Tony mentions above. Otherwise, as Tony says, just a change in the plumbing.
Ole S Olson
Posts: 373 Likes: 1
Thank you for the replies.
VCCA Member 51121
