Thanks for the suggestions. I'll look into both options. I have the old sweeps removed and am thinking it might be pretty hard to use the original staple holes. Might be easier to drill new holes if I go the staple route. With the panel bond, I guess you would have to have the mounting surface down to bare metal, correct? I am not too concerned in having an all original 100 point car as I couldn't afford to do that anyway. So thanks again for the help, I'll come back and tell or show what I wind up doing. Mike
