Does the guide 6002 switch need to be grounded.there is no ground wire attached to the switch but my new harness has one??chef- chevy
The switch is grounded by the clamp around the steering column. Take a stiff shot of your favorite brew and scrape the paint where it mounts. The switch must be grounded or the indicator light will not work.
Agrin
I thought I could solder a wire to the switch body,run it though the loom and gound it under the dash?The switch body being pot metal would not except the solder????chef- chevy
You should find a place inside to attach your ground wire. That is a more reasonable solution vs scraping the paint.
Agrin
Thanks Ray,that will be my plan then,chef- chevy
