#45776 03/25/06 07:10 PM
jwp Offline OP
I am replacing the plastic insert on my 1928 light switch and have a couple of questions; should the rotating element of the switch be lubed? If yes what lube should be used?
jwp
#45777 03/26/06 01:22 AM
Vasoline works quite nicely.
Agrin
#45778 03/26/06 06:50 PM
There is also a product that looks very similar to Vaseline that is sold at swimming pool supply stores for use on outdoor switches and PVC pipe threads, etc. I was told (by the pool mechanic not the seller of the product) that I needed to use it instead of the Vaseline I had been using...suppose to not attract dirt or whatever...
I’m not by any means an expert on it I just wanted to pass the information on to you it might be 'mouse milk' but it does work great.
#45779 03/27/06 01:38 AM
JWP,
You don't have to be a rocket scientist to realize Ray has forgot more about 28's than most others have ever learned. Stick with him on this one!
Gator's recipe will probably get you a good batch of mouse cottage cheese!
NG
Napoleon Goode
