#457710 05/22/21 12:42 PM
Tiny Offline OP
The gas cap on my 53 isn't vented. It looks like the big brother of the cap on my 38's road draft tube. I have no idea if it's the OEM cap or not. I've had no issues with driveability because it's not vented which makes we wonder how the tank is vented?
Tiny #457718 05/22/21 06:15 PM
The 1953 had a vented cap...............same cap as a 1955-1957.
Tiny #457719 05/22/21 06:50 PM
Tiny Offline OP
My cap looks like this. Is it vented? It doesn't appear to be.
Tiny #457734 05/23/21 05:38 PM
It is vented but you would need to remove the rivet to see the vent method.
If it was not vented you would go only a few miles befor fuel delivery stopped.
Tiny #457741 05/23/21 07:09 PM
Tiny Offline OP
I read on Eckers that there's a vent slit in the filler neck & the cap is unvented. I'll take a closer look at my cap.
Tiny #457766 05/24/21 12:12 PM
Tiny Offline OP
Mystery solved. The cap isn't vented. Ecklers says there's a "slit" in the filler neck for venting. I took a look this morning and snapped some pics. It took me a while to find the "slit" in the neck. I'd call it a "notch" instead. In the picture of the neck look at the 12 o'clock position. You'll see a small notch in the rim that acts as the vent.
Tiny #457965 05/31/21 07:49 AM
I stopped to get gas a few days ago and when I removed the cab I got a sudden rush of air from the tank. This is after the car had been driven several miles on a really warm day. I had never noticed this before.
1951 styline deluxe sport coupe w/54 engine and power glide
Tiny #457968 05/31/21 09:27 AM
Check the cap or tank vent as it likely is plugged. There should be a vent on the tank to equalize pressure inside and out. Otherwise there is a likelyhood of partially collapsing the tank or restricting the flow to the carburetor.
Tiny #457998 06/01/21 10:53 AM
This is a response to Pidlar’s post. Most of the gas caps that are sold as “retrofit” for these older cars are not true reproductions. Most of them have spring loaded either vacuum or pressure or maybe both relief valves. The original gas caps did not have those.
I think I have 3 or 4 replacement fuel caps I have bought over the years for my ”˜37. The one on the car when I bought it did not seal adequately so gas would spill out the filler when the tank was even 3/4 full. Currently I have one that seems to work fairly well. It does get a slight pressure build up on hot days but it seems to work ok to prevent a vacuum problem. As Chipper noted that can cause lots of issues.
