#457641 05/20/21 07:30 PM
Tim1927 Offline OP
I acquired an engine from a fella who died before he could finish his project. When I pulled the head #3 cylinder had grooves cut on both sides ( front and back). Any idea why they are there or what for? Compression gas would just blow by. I would add a pic but don’t know how. Thanks Tim
I wonder if the wrist pin is loose in the piston. It could move back and forth and dig into the cylinder wall at the front and rear.
Tim1927 Offline OP
It looks like that could be it, The pin was tight when I pulled the piston, but maybe the other fella tightened it. It will have to be sleeved for sure. Appreciate the reply.
Your wrist pin was seized and caused the damage. You can have the cylinder sleeved and march on. Be sure and fit the wrist pin correctly when you reassembly.
I believe the wrist pin should remain tight to the connecting rod. if it's the same as the 6 cylinder. The damage occurs when it becomes loose and moves front to back while running against the cylinder walls and causes deep grooves requiring the block to be sleeved.
You are correct!
Tim1927 Offline OP
Thanks to you all. It will be sleeved.
Just make sure that when you get the cylinders sleeved,that the machinist stops the bore for the sleeve about 1" from the bottom.This way,once the sleeve is fitted,machined etc,there's no possibility for it to move,as it's "held" from moving in the block by the "stop" at the bottom and the cylinder head at the top when you assemble the engine.A mate had his '24 Dodge 4cyl engine sleeved with the sleeve bores running right through,and every single sleeve moved destroying the block.Just a thought.
CJP'S 29
My local machine shop uses sleeves with a machined lip at the top. He bores suitable recess at the top of the bore and fits the sleeve down hard to the recess then takes a light skim accross the top so the sleeves are then flush with the top of the block. I have watched the process a couple of times.
That is a neat way to sleeve and lock it into place.
It means there is continuous material top to bottom rather than the possibility of a lip wearing to cause problems. Depending on the original setup he wont do Alloy blocks as the different expansion rates of alloy and steel they often wont stay in place, while some dont stay in place from the original casting.
