Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I went to open my trunk and the right hand hinge separated. On inspection the pin had worked itself out of the strap and was protruding out the left side of the hinge. The end of the pin has a larger head that is serrated . The other end does not stick out the other side as the hole is blind.
I am wondering about using loctite to secure it.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Loctite is likely to be successful now that it has moved. Tony
