My54 Offline OP
I am trying to remove the plate that the voltage regulator is attached to. What kind of tool fits the plate screws?They are not slotted or phillips I have never seen this type before.
Clutch head, that’s what I have always called them.
That is what I call them also. They are somewhat a “security screw” design. You can install them with a slotted screwdriver but they are hard to remove without a clutch head tip.
In a pinch you can use a flat screwdriver if they're not rusted in place. If necessary clutch head drivers are still available.
My54 Offline OP
Thank you both for your replies.Out tomorrow to pick one up.
My54 Offline OP
Bought a clutch bit and easily got the plate behind the voltage regulator off. Next part was a little harder taking the two nuts off of the back of the speedometer but got it done and shipped the speedometer out for repair.
I just took mine off over the weekend. A screwdriver worked perfectly fine but my screws are not rusted and are in excellent shape.
My54 Offline OP
I had two that would not come out with a screwdriver the clutch head bit took the two stubborn screws out with ease.
