Hello Everyone Im 26 and just got handed down a 1928 chevy i want to restor just wondering what i need to start the best websites for parts or if there are any manuals out there everything is in good condition been sitting in a barn in nabraska for 50 years and ran last time it was parked there the crank turns and 3 out of the 4 tires stay up:) so just gotta know where to start. Thanks
Hello
Welcome to VCCA. You certainly have an interesting project. Always loved the 27 and 28's.
Since the engine turns I'd suggest getting it running and access how things go. Not sure how far back some vendors go but I think JimCarter may go back that far. I'm not familiar with that vintage but some more guys will chime in later with advice and opiinions.
...got to have a plan. For me I try to work on my projects EVERY day, even if its only 15 minutes. Getting a vehicle to GO and WHOA is half the battle. Once running it will "talk" to you and help you decide what to do next.
This is my own personal opinion but after several resto's I have found that it helps me to "repair or fix" the individual pieces as I take them apart. Example: fenders are blasted and primed ready for paint.....glove box ordered when I see I need one, glass and regulators fixed as I do each one. I think you see my logic. You always have something "finished" to motivate you and your not looking at a pike of stuff in a corner that you can't afford to fix all at one time. Its so nice to blast and finish the chassis and have all the goodies waiting ready to go back on. I also buy tires as the last thing. No need to buy'em and let them set and get flat sided. (unless you get it drivable quickly)
Take a little time to decide which way you want to do and get started.............keep us posted and be sure to post in the appropiate forum for answers to your questions and check out the forums for your specific year. Good luck. Post some pictures when you can.
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
Welcome to the VCCA Chatter Forum. You have come to the right place for help with your '28 Chevy. There are several that frequent this site that have owned and driven similar cars for decades. Many of us routinely drive and tour with our 4 cylinder cars and trucks.
There are several manuals that are available in reprints. Owner's Manual, Repair Manual will be of most help in understanding how it works and common repairs. They are available from the Filling Station (https://fillingstation.com) a Chevy parts seller in Lebanon Oregon. There are also other literature dealers that have them as well. The Filling Station also sells many replacement parts for your '28. A search for 1928 Chevy their online calendar will find a bunch.
First take 5 times the number of photos of every part, exterior, interior that you think might be helpful to document the condition, how to put it back together, which parts are needed, help others know what part you are asking about or just to put in an album for others to appreciate what you started with and where you are now.
Our general recommendation for reviving a long stored vehicle is to determine the general condition of wiring, drive train, exhaust, radiator. Are they safe, contain at least some of the required fluid? Does it look okay?
The engine is a vary important part of any vehicle. I suggest remove the engine oil pan, scrape out the sludge, clean the pan, inspect the parts including the oil pump screen and oil pan for rust and possible holes. Also check the water pump, generator, starter to be sure they rotate, clean and lubricate as necessary. Take off the distributor cap after documenting the condition and location of wires.
If it all looks clean then all you may need to do is clean the points with file, wife's emery board, fine grit sand paper. Take off the valve cover, lubricate the valves, rocker arms, shafts, push rods and sockets with motor oil. I use a brass drift (rod) and small hammer to check each valve to be sure they are not stuck. Put one end of the drift on the top of the valve or rocker just above the valve stem and tap to see if the valve moves down and immediately back up with only valve spring pressure. Replace gaskets with new ones. Wet the short pieces in the oil pan gasket set with water and wrap them around a beverage can. Hold them in place with tape, rubber band, plastic wrap overnight to dry with an arc. Once reassembled put in 4 quarts of 10W-30 or 5W-20 detergent motor oil. Seriously consider documenting the location of distributor rotor and removing the distributor so you can spin the oil pump to be sure the pump operates and there are no significant leaks. A drill with rod having an end matching the bottom of the distributor shaft works well. Once that is done then return the oil pump shaft to the same position as when the distributor was removed and reinstall the distributor with the rotor in the same exact position as when removed. [Caution: do not rotate the engine while the distributor has been removed unless it was at top center of the compression stroke for No. 1 cylinder and is restored to that exact position]. Inspect the carburetor and vacuum fuel pump. It may be best to use a small temporary gasoline tank if there is any doubt on condition of gas tank, lines, fuel pump.
Once the engine is prepped, make sure the battery posts, cable clamps and ends are clean, corrosion free and cables in good shape. Be sure the cables are large enough for 6 volt systems and battery fully charged. It is not necessary to fill the radiator with water if you only run the engine for less than a minute to get an idea of its condition. Once you determine the running condition of the engine then check the transmission, cooling system, etc. If the engine has problems then it may need to remove it which requires removal of hood, radiator, etc.
Hi Nathan,
You found the best place for info and sharing lies about old Chevys!! ;-) What a special hand-me-down!
As Chipper said, getting a copy of the manuals is very important and taking LOTS of photos is imperative!
In another thread, I described my opinion about how to tackle a project that has been sitting for many years. Here's a link to that post: https://vccachat.org/ubbthreads.php/topics/359959/re-1927-landau-imperial-restore.html#Post359959
I suggest that you start a new thread in the 1912-1928 forum to keep track of your project/ladventure because that's where the folks who are interested in that era hang out.
Celebrate every step you take with your new toy and enjoy the journey!
We can’t wait to see some photos! It sounds like you are very fortunate to have a gem of history. I would say that the Filling Station is one of the best sources for parts. This website is also a great source to find NOS parts. I look forward to reading about your journey. Bringing an old engine back to life is a thrill like no other, believe me!
Welcome to the VCCA. The above people can help the most.
sounds like a great inheritance! look forward to seeing photos, i love seeing things emerge from their caves and rejoin the living!
get familiar wuth:
filling station
Marx parts
hagens auto parts
early chevy parts aka Gary Wallace
also read read read on here, i joined last summer and still learn something every day.
