#456186 04/06/21 08:19 PM
rck46 Offline OP
Here are some pictures of a 42-47 radio that I have restored. It is United Motors Service Model Number 986146, The speaker is mounted inside the chassis enclosure which is the truck configuration. When I got the radio it came with a speaker mounting plate (see last picture) which I assume is for external mounting. Is this what was used for mounting the speaker in a car? Was this a dealer installed radio? Any additional info you might have on the application of this radio would be appreciated.
Thanks, Bob
IMG_0013, resize.jpg IMG_0014 (1), resize.jpg IMG_0015 (1), resize.jpg IMG_0018 (1), resize.jpg IMG_0019 (1), resize.jpg
Support The VCCA!
That radio is a universal radio for use in the truck or car. The speaker is mounted inside the case for use in the truck. When mounted in the car the speaker is removed and mounted on the plate shown in figure 5 above. This plate is mounted upright on top of the case so the speaker faces through the dash.
The radio operates marginally in either the truck or car due to road noise.
devil Agrin
rck46 Offline OP
Thanks Ray for the info.
I restored one that was installed in a COE. It turned out that it was impossible to hear going down the road!
