Page 2 of 2 1 2
#45607 09/16/05 01:32 PM
MR MACK
basic electricity theory is not quite correct.
current leaving the battery must return to the battery. the internal resistance of the device determines the voltage drop across the device plus the current thus the formula (p=ie) POWER IS THE HEA OE ENERGY DISSAPATED. I is current. e is voltage applied. the current on the ground side will be the same as current on the hot side.
1928 NATONAL AB COUPE
#45608 09/16/05 02:41 PM
Bob.....if you mess around with old cars and trucks as much as some of us have...you will be drinking beer sooner or later!! ha ha! bigl bigl bigl bigl
#45609 09/16/05 08:07 PM
Hahaha! Maybe after my truck is done I will sit back and have a cold one! Or perhaps the day when I will get my cab back from paint and end up accidentaly scratching or denting it!
1939 Chevy 1 1/2 ton dually rear wheel pickup
1940 Chevy 1 1/2 ton single rear wheel pickup
1946 Chevy 2 ton cab and chassis
1977 Chevy 3/4 ton camper special 4x4
Obsessed 16yr old Chevy truck nut
#45610 09/16/05 08:36 PM
The latter will definitley cause you to start drinking beer with the boys! ha ha! drink drink drink drink wink laugh
#45611 09/17/05 12:49 AM
Huffneff were you that guy teaching basic E.E. RC circuits at the college where I got a C+?
I guess the power company is screwing all of us if the current going back to the power line is the same as the current coming in, then because the voltage is the same too, I wonder how they say that I used any electricity, I guess we are just renting it for a while to run all our appliances?
#45612 09/17/05 06:42 AM
MM
You got that right but at the prices I been paying I thought I was buying the company
#45613 09/23/05 03:21 AM
Does anyone have a detailed wiring diagran of the headlight switch? Before me someone must of tried to re-wire it. I have no park lights nor high beam lights.
#45614 09/23/05 10:01 AM
8thairforce-What year car (or truck)??????
#45615 09/23/05 10:50 AM
His car is a 1931, and I have emailed him an illustration of a 1931 wiring diagram. wink laugh laugh laugh
#45616 09/23/05 01:28 PM
mr mack
just read your question. the voltage drop is across whatever load you are using. the larger the resistance, the less current is used.electricity is like a closed water system. all current that leaves the positive post must return to the negitive post.the voltage at the positive post is 12 volts. the voltage drops to 0 volts across the load and this drop is defined as power.if the current was less at the negitive post you could use a much smaller groud wire than the positive wire. the electricity company is charging you for the power you use, not the current or voltage. the bill is in kilowatt hours which mean power. that is a combination of voltage applied times cureent flowing through the device and is dissipated in either heat or energy.
#45617 09/26/05 08:27 AM
Thanks for the wiring diagram for the 1931 headlight switch. It is so small my eyes can't focus on it. I tried blowing it up but it just gor blurry. I hope there is help out there. I just need a detailed diagram of the 1931 headlight switch. Thanks.
#45618 09/26/05 10:13 AM
The diagram that I sent was a fairly large illustration. Must be your computer settings. :confused: :confused:
#45619 09/26/05 09:18 PM
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Try this one.
Bill\'s 1931 Site
[Linked Image from 1931chevrolet.com]
Bill Barker
(VCCA Member: 9802)
#45620 09/26/05 11:54 PM
That outta be big enough! :eek: :eek: bigl bigl bigl
Page 2 of 2 1 2
